Ran into afpr problem see my last post... VIDEO OF PROBLEM
you set the base pressure without any vaccum line. then, once the base pressure is set, you connect the vaccum line again :thumb:
ahhhh ok thank you very much, that explains alot :)
ok now i ran into a problem, i try to set the afpr and it only stays within 0 and like 35psi, wont go any higher... which way should it be to set it (clockwise turns lower counter higher???) idk whats wrong, i may need to get a video of it
its a ebay fpr, my friend bought it for me for like 20bux shipped or something.... heres the video...
http://www.freewebs.com/jdxcc/afpr.mov
Dont be alarmed it (the fpr) is flopping around because i took it off its mount temporarily.
I think you found your problem. Sometimes it's a good idea to stick to name-brand products.
Did it come with any instructions?
I agree with ^^ time to get a different AFPR, at least you didnt spend a lot on that one, you best bet would be to just get a Aeromotive, something that has been proven to work well.
