radio help !!
xxking9
31
Nov 20, 2011
richmond, Virginia
I have a 92 eclipse. Someone before me hacked the harness. Plug I need yo know which color is what so I can temporarily. Hook up my stereo till I can order the oem. Plug and then an adapter. For the stereo. The little plug is there, would like to know what they all go to. Thanks it's an awd. Turbo but that doesn't matter factory radio was a double din I believe.
Actually, it can be either single DIN, or double DIN - depends on what the factory put out for audio options.
But, turbos had the double DIN radio setups..and some even had an amplifier below the radio to help run the six speakers..
1st Gen Radio Plug
Best thing for what happened in your case, is head to a car radio shop for a harness that can be hard wired to the existing wires since that harness will have the same wire code config as the stock setup.
