Quick wiring help.
Whiplash
1,624
4
Nov 29, 2004
Detroit, Michigan
Guys I have a problem with my CD player. Everytime I turn off the car the CD player resets itself. All my settings are gone and I have to start the CD from the start, everytime. At first it didnt bother me but now its pissing me off.
This is a wiring diagram for the CD player.
Here are my connections. I think one (or more) is wrong.
From CD playerm to Car wire
Blue --- Nothing
Yellow --- Blue
Black --- Black
Red --- Red with grey dots (not very many)
Green/Black --- Blue/Grey
What do you guys think?
Marry Christmas, and thanks.
It sounds like your memory isn't connected to a direct power source.
Splice your memory line to the direct 12v wire. Orrrr... Get yourself a nice wire harness, so you don't have to worry about it :p
Howie~
heres how it should be, for a 2g and for your deck
Deck ------- Car wiring harness
Red -------- Black/White
Yellow ----- White
Black ------ Chasis Ground
then the speaker wires should be hooked up correctly if your cdplayer is working.
like sojoo said, your memory wire is either not connected or its connected to a switched power supply, this memory wire needs to be connected to a constant power source even when the ignition is off,this will retain all your settings.
I had my red and yellow wires wrong. So I switched them and it works fine now.
My car has been doing this as well, but it's the stock Infinity system. If I shut my car off, and then turn it back on within a half hour or so, it's fine, but if I'm gone for longer than that, all my stations reset, and I have to re-enter my code every time.
