Quick turbo rebuild question "16G"
The little tin piece on the right is the heat shield. I have seen "ebay" 16g turbos that didnt have this. If that is not it, i will let someone more knowledgeable than myself chime in.
I did not rebuild the turbo, I took the hotside off to remove the wastegate flapper. This is a genuine B16G. The heatshield is in good condition.
This gap does not get smaller when clamp is secured around the housing. No carbon buildup, and dimple is in the hole.
That picture doesnt look as bad it sounded when you described it. If it were me I'd run it.
I am being plagued with a spool issue on my car. Dont wan't to get into details, but I have checked everything. After putting turbo back together, I noticed this, and am hoping this could be a cause. Not sure if that gap is enough to make a difference in boost pressure.
