Quick S-AFC Wiring Question
RJD2
67
May 3, 2007
Madison, Alabama
I just installed some RC 550 injectors and a S-AFC I and I started the car and everthing seems to be fine, cuts off when I cut the car off, but when I cut the car off and the back on all my settings are gone. I'm guessing it's the power wire but where do I wire it to then??
Don't bump your own thread. Specially after just one hour on the forums! The best you can do is verify that you wired the S-AFC correctly using the ecu pin layout here.
Are you sure you have everything hooked up tight and secure? I would just go back and make sure everything is right - especially your ground and power wires and match it to the diagrams on the SAFC2 website.
did you check and see if you there is a constant power you might have just hooked up the switched same concept as a head unit....
I would assume the same thing. Everytime you turn your car off your SAFC is no longer getting a constant power, hence why it would think that the battery is dead and "initialize (reset)" itself. Try wiring the constant to a better power supply like the head unit wire.
