Quick question about the new style AFPR
RipperXX
5,786
172
Feb 23, 2003
Royston, Georgia
I just got one of the new style'd aeromotive FPR from diamondstarmotorsport, anyway im not sure which line goes where on ther regulator, do I connect the line from the fuel rail to the bottom or side connector?
So theres a side and bottom AN fitting, and I need to know which is the return line and which I connect the fuel rail to.
Other thing im wondering, is since I removed my whole A/C system, can I remove the fuse box on the right (drivers side) on the firewall that has fuse's and relays for the AC system? Or do I have to keep it so the vent / heater fans work?
I would imagine you would need them for your fans but I'm sure there are a number of ways to get rid of it and control your fans in some other form.
Did you not check out that first link I sent or try a search? You should have plenty of room because mine is on the firewall. I just used an exsisting bolt and used the bracket my fpr came with and voila I was set.
