Quick Lower Front Cover question
jlado13
88
Aug 6, 2007
Rohnert Park, California
I'm assembling my new 6bolt block and don't have the lower front cover gasket. Will some sort of hi-temp rtv suffice, or is the specific gasket a "must have"? Thanks in advance.
Jordan
i would HIGHLY recommend using the gasket. it's a tight thin area with oil channels that you risk blocking from excess gasket maker. your local parts store should have a front case gasket set for about 20 bucks :) it's in your best interest to not use the gasket maker and to use the proper part "the gasket" :)
