Quick: Fender removal question
Mytrn2brn
145
Mar 11, 2006
buffalo, New York
Hey Guys, Sorry if this is a repeat, do you really have to take off the front bumper or headlight to take off the front driver side fender?
Thanks
I didnt.
There is a bolt that goes right in behind the turn signal, I used a combination of crazy twisting extensions and got down to it from the bayside.
You don't have to take out the headlight or front bumper but you'll need to remove the 2 bolts that bolt the fender to the bumper and also the other bolt hidden right behind the turn signal part of your headlight (that will be a slight PITA). Other than that all the other bolts are pretty easy and visible.
