1g fender removal
25391tally
49
Feb 23, 2009
university place, Washington
how do i get the side skirt off the fender i dont want to break it is it ok to just pop that part off or what am i missing the fender moves but does not want to budge from the side skirt?>..:hmm:
so take off the whole side skirt and the fender ?
are the underneath the sideskirt ### i took two off from there already but i should be ok to take a flathead and just pop it off ?
it still wont come off pry it apart and be careful ?
The corner piece of the front part of the sideskirt is attached to the fender, Remove it all in one piece.
I just poped it off of my fender to get the fender painted.Nothing got hurt!
Make sure you got the two bolts on the bottom of the fender.
If all the bolts are out you will be fine.
Pop your hood, remove the bolts there. Open your door there is one in the door jamb, and under the side skirt remove the last two.
They are all 10mm.
