quick vacuume removal question
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
Alright fast question i got the taboo vacuume removal pictures and i saw it doesnt have the emissions canister on the 2nd picture so im thinking u remove it.. so i removed the vacuume hose that came off it and that goes to the fire wall, and started the car (pluged off both ends) and it ran like crap, is it cause all the vacuumes where still plugged into it? or do i leave it in there?
Not sure if you covered this but the hose that is coming from the firewall should go to the gas tank, don't block this one off, this will cause vacuum lock and starve your injectors.
Hope this helps.
This is how I have mine ran. Red lines indicate vacuum.
Everything is else is removed or closed loop.
Im talking about the emissions canister under the battery holder theres 2 hoses that come out one that turns right around and goes into the firewall and the other that goes into a port like thing that turned into 3 more hoses. i plugged the one going into the fire wall? ill try ot post a pic from paint
Ok the part that says blocked i removed the hose and blocked off both ends, Im hopeing it was running bad cause i havnt took off any other lines too it all of them where still going to the canister
i removed all those hoses except the needed ones. just make sure that you have the other ones capped off. i just took to pieces of hose and looped the 4 ports on the TB.
