Question of Compatibility
flynspyder
Feb 16, 2005
Granite Falls, Washington
I own a 1998 Spyder Convertible with the 2.4L SOHC engine (the dodge engine) and it is absolutely impossible to find performance parts for that engine, SO!
I want to purchase a 4G63 GST engine and drop it in instead. I need to know if the 6-bolt 4G63 engine will drop right in and bolt right up to my car or is it not going to fit? Also will I be able to keep the same manual transmission or will I need a new one?
Please help
flynspyder
First off, your motor is Mitsu, not Dodge...you have a Mitsu SOHC 4g64 motor. You can get a 4g63 head and bolt that on, and I believe you can get oil lines, exh mani, etc to put a turbo on that one if you want. That way you have a 2.4l turbo instead of 2.0l turbo.
Check out this website for more info:
http://www.4g64.com/
Alright, that makes sense. I'm going off what I was told at by this guy, Kevin, who owns a customs shop. I'll check it out though. Thanks alot!
