Question about wiring a FM Modulator: Power using ACC circuit okay?
DSMRevolution
1,629
11
Dec 6, 2002
Sioux Falls, South Dakota
Hey everybody, I have just a quick question about wiring a Kenwood FM Modulator.
What I want to know is if it is alright to leave the FM Modulator powered constantly (hooking it up to the ignition accessory circuit). Will this interfear with radio reception (if I am listening to a radio station) if I am not tuned to the correct station that the FM Modulator is setup for?
Thank you for your help! :cool:
depends defiant, some DO affect the Fm reception when on, most of them do that are actually on the antenna wire itself.
wire it to accessory and put a small toggle somewhere.
Ok thanks for the help Defiant and Attack Eagle. :thumb:
I had the FM Modulator hooked up before in my hatch area, but I think that caused some problems. The reason I wonder is because the audio output was never very clear. I have heard wireless FM modulators that have sounded better. I think the problem was because the audio signal from the modulator had to travel about 15 feet through the antenna wire to reach the CD player antenna input.
I am in a huge process of rewiring 95% of my aftermarket electrical accessories right now so hopefully moving the FM modulator to the front dash area (direct input signal to the CD player) will have a cleaner signal.
Regarding my question... I am making a fused accessory panel (for all of my aftermarket gadgets) that is powered through a relay switched by the ignition accessory turn on wire (I hope that made sense). Anyways, this will clean up a lot of my wiring under my dash and eliminate a few panel switches (hopefully help get rid of my jet fighter interior look).
Thanks again!
since your doing a nice fused bank of switches off a relay anyways (yes, it made sense to me) i'd put your FM Mod on a switch too. it will guarantee you no interferance if you turn it off when not in use.
