question about turbo differences
16g flows more.. PSI is just a measure of pressure. Pressure is only half of the picture. At the same pressure the 16g flows more air. Which is the most important.
The 16g flows more lbs/min (pounds/minute). That is why a 50 trim at 25 psi will make less power then a 35r at the same psi. That is also why a stock bottom end can handle more psi from a 16g then it can from a 42r. You wouldn't run 30psi with a 42r on stock bottom end would you. A lot of people do it with a 50 trim or smaller though because they flow less air so they aren't putting as much strain on the car.
erald01 said:
16g spools faster..did you notice that you build full boost at 3200 rpm compared to t25 which i think builds full boost at 4300-4500 rpm. Thats Why.
WRONG. Please don't post unless you are positive about what you say.
What I said is the reason it pulls harder. And the t25 spools faster then a 16g will. And there is no set rpm that the turbo will spool at, it will be different with different cars and set ups. If you have a t25 that spools that late something is seriously wrong with your car.
WTF I promise I am not trying to single you out and pick posts apart. but the 16g does not spool faster than a t25.
