question about ingall camber kits
m0nk3estylez
62
Feb 10, 2009
stockton, California
Anchor mounts it is. Trying to find the delete button.
Yea I was wondering what you guys recommended the upper ball joint kit or the control arm mounts and have anyone use the control arm mount?
I'm still deciding if I should get the control arm mounting kit.
Car is 2in drop
I currently have the anchor bolt style. They REALLY suck if you need very much camber adjustment. It will push the whole control arm out enough that you will have fender well clearance issues. Also I found that mine will slip if I hit a bump very hard or now that the anchor bolts are screwed up from hitting bumps they will slip from a hard turn. I also had my suspension get jammed up into the fender well in the compressed position before I bashed some extra clearance into the fender well with a sledge hammer. Just some friendly info.
