Q45 throtlebody users please come in
bento
94
Feb 14, 2008
harrison, New Jersey
I installed a Q45 throtlebody in my car. I hooked up the tps sensor but i cannot get the car to idle propertly due to the fact that it has no iac motor. Is there a way to install the stock iac motor in there? How do you guys get the cars to idle propertly? I do realize that the nissans have the the iac motor installed in the intake manifold seperatly from the throtlebody.
Does the car idle poorly only when cold or all the time? I have to give my car gas (slight throttle tip-in) for the first 30 seconds or so and then it idles progressively better until fully warmed up. Once warm, it idles as good as stock.
The 1st minute when cold i have to hold the gas pedal but after that it's ok, but not great. It's not a steady idle. I'm trying to maintain it at 1200 rpm or so because i got cams. I guess it will never be steady.
Mine is throwing a tps dtc in link and does not idle well even after a few minutes...
Nevermind that. Got the tps to read some and set the range 0-100% and everything and no more cel for the tps. Car still runs shitty though. idles very rough and wont stay running most the time without my foot on the gas. W/b shows like 10.5-12 a/f which means way rich. The only things ive done to the car mostly is brand new fpr, brand new tial bov, brand new tial wg, jmf smim and the q45. All of which are less restrictive to air than before. Any ideas?
You'll need to do adjust the BIAS. It's a small 8mm lock nutted flat head screw on the linkage side of the TB. screwing it clockwise opens the TB butterfly lightly to allow some air to bypass. You'll need to readjust your TB offset to accommodate this.
Yeah ill play with that a bit. I believe it mostly just adjusting sliders and whatnot because it doesnt rev or run any better at higher rpms.
  • For sale 2g 2G Mishimoto Radiator
    2G Mishimoto Radiator $175 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Valve Cover ( No broken bolt holes or cracks )
    Valve Cover ( No broken bolt holes or cracks )* great candidate for powder coat or paint *...
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
  • For sale 2g Misc parts
    Have a few things for sale. Open to offers, located in Toronto Canada but can ship- S90...
    • Bedicine
