Q about 2G radio antenna...........
aztek_warrior
48
Mar 9, 2005
Marshall, Minnesota
Story is my radio antenna got jacked when i was at work.......... :mad:
I live in a small town and i know im not going to be able to find
one from another Mitsubishi around here so my Q is since the cars
are assembled by dodge are there any models from dodge
with this type of antenna or does it have to be an eclipse antenna???
Or is there a place i can just order one from, other than a dealership??
I got a 95 GS (*no pw antenna)
HeDog said:
I think that I still have mine from when I put in my power antenna.
Do you ever get over to Rochester? If you do, and I can find the old antenna, you can have it.
Not really, my job keeps me in town
most of the time. I've tried about the
only audio shop in town but they want
an arm and a leg for it, cause they said
they had to custom order it........... :notgood:
thats the bad part of living in a small town.
is there an antena that just mounts to your back glass? I was thinking abut trying to find something like that since my power antena got broke off. It'd prob. weigh a little less too.
iight check it out, i shaved my antenna and still wanted it so i stole n idea from tha older rx7's. if u look at the windsheilds in the middle they have 2 copper thing strips commin down, i went to lowes and got sum thin copper wire and lined it around the edges of my hatch. radio works awsome.. don't use it too much but still it's clean and easy not to mention super cheap :thumb: :dsm:
I went to Frys Electronics here in socal and they had a universal antenna thats a simple plug into the back of the deck. Then I ran a cord up through my passenger side pillar and its a little black box about 4" x 1" x 1" with adhesive on one side. I just stuck it at the top of the front window passenger side. Reception is perfect. Wasnt too expensive either like 15 bucks? im not totally sure on that.
would just have to make sure its compatible with the deck you have. (mine was kenwood - forget the model tho)
