Putting a Turbo on a non-turbo
19clipse91
Dec 8, 2004
Williston, North Dakota
I have a 1991 Mitsubishi Eclipse with a 2.0L. Im looking to up grade to a turbo. Which is the cheapest and which is the best way to do this?
Many people will tell you to do a search.. the answers are all there.
You can prolly just take the parts from a turbo 4g63, but keep in mind your fuel system isn't mean for a turbo, the compresison of the motor is not meant for a turbo so you won't run as high psi as a turbo engine. But look on the buy and sell for used 2g manis, old t25s, or 14b... get some custom piping or stock IC pipes, stock or bigger injectors, and hope yer ecu can handle the change. Other ppl upgrade all the time, so they look to pawn their stuff off all the time.
Im not experienced with this myself so this list is not complete.
there is a tech article on how to do it under the turbo/fuel heading. i believe it was user xhypno who wrote it, unfortunately for you i don't know if he's still a member of the forums, or at least not an active member.
    • Sdcryan1
