PUNISHMENT RACING IC.. Installation problems.. users please help
mitsuboost30
Feb 17, 2008
SE/PA, Pennsylvania
Whats goin on guys..
well i got the punishment racing front mount kit (THIS KIT!) for Christmas and am trying to put it on now.. everything was good until i put the IC up to the car and realized that the power steering lines and one of the ac lines coming the thru the frame where i have to cut are in the way..
i know alot of people have purchased this kit.. whats ## experience and how did u get around it..
please help ASAP.. car cant run until i have this on.. Thanks in advance
well from what i hear and thought at first i need to just make a u ling for the power steering line..
but thanks for all the knowledge and great replies!
I have The same kit I removed all of those lines and trimmed the hole you should remove the power steering lines and the ac anyways.One other thing is you want to watch out for the wiring harness to the left of the right side and the right of the left side on the inside of the hole .It does work though just a bunch of stuff to move or tear out witch is my recomendation.:thumb:
I carefully cut the holes with the lines in place,cleaned up the sharp edges and left them right there.I also wrapped them with a piece of rubber because it gets a little tight .
ok well i appreciate the people that did reply..
We got the kit on last night after every possible problem we could run into..
