Pulling Codes, almost there, can someone translate?
triggerx
364
10
Aug 15, 2009
Gilbert, Arizona
So heres the deal. Ive searched on the forums and ended up finding a way to check the code with a buzzer.
(ID be more than happy to write up a detailed how to if theres not one present.) So Ive got everything connected, i just dont know how to read the code its putting out, and where does the code start.
But here it is
S= Short
L=Long
S, L, L, L, L
So it keeps repeating this samething, but Im not even sure if I started it off at the right point ### it could be
L,L,L,L,S.
Anyone know what code im getting?
Im thinking its 41
ok so the problem is the fuel injectors. Are the injectors in these cars suppose to be able to rotate?, ### they seem kindda lose
Not really, but yes. I know that doesn't make much sense so let me explain. The seals are probably old and dried out/shrunken making it very easy to rotate them. With a new set of seals the injectors will be held in the rail and the intake manifold much tighter and would be harder to rotate, although they still will if forced. Yours are just easier to rotate because of the old seals.
So is it possible that the lack of or aging of seals is causing the car to throw a cel code 41?
anything is possible. Leaky injector seals will give you boost leak issues so you should definitely get those fixed up, especially since they are cheap to do and fairly easy.
As far as your code 41: that means something is hinky with the Injector Coil Resistance-- Use a volt meter to measure the coil resistance of each injector and verify if within spec or not. S/b within 2-3 ohms iirc but check a chiltons/FSM/search here to verify the spec you need.
You'll also want to check the wiring for obvious nicks/wear/damage and make sure the connectors are nice and snug on the injectors.
Key point here, a 41 fault code won't have anything to do with the seals. It's electrical.
When your listening to the codes you'll note there is a different pause space between the codes vs between the digits. The longer pause marks the space between codes even when it's just repeating the same code.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
