Pulled Timing for some reason?
pecka
61
Jul 20, 2004
Valley City, North Dakota
Well, tonight I went out and tried to do some tuning with my afc. I wish I could post the logs I got, but since I got Vista I have been unable to load them to my computer. Could anyone tell my why my timing is only advancing to 13 degrees? There must be knock somewhere, but my timing graph is smooth up to the 13 degree peak. I am on stock injectors, a walboro 190, and a 14b. Anyone have any suggestions? I tried adding some fuel, but it didnt really seem to matter.
***May I also add even though the timing is showing that it's being pulled my egt's are solid at about 1550 deg.
Hmmm, well posting a log would solve your issue. What logging software are you using? I'm running Vista with OBD Gauge software for the logger and I can load 'em up fine.
If it's progressing smoothly with no dips on the way up, you might want to check your coolant/ air temps.
Try to get that log up.
Was that at WOT? If it's at 13 at WOT then I'd say that's not too bad at all. I think you were right when you said it could be knock, but that's not very low timing for 3rd gear pulls or something. I'd say grab yourself a wideband as soon as possible, but also turn down your boost and see if that helps. If it's at 13 when you're just idling or cruising around town that seems way low. What are your coolant temps like? That can cause the ECU to mess with the timing too, but that's at really high temps.
Your logs would be good to have, but let us know more about what rpm and boost level the timing started to not climb as high at. It's allright if it's wide open though, but if you want to go anymore you should get some fuel support. I'll check back and try to help some more, but I'm just guessing because there's not much to go on.
I'm using palm'n stein and it blows, I know. The pulls were at WOT. Do these help?
#1
Rpms Timing O2V
3000 13 .91
3224 6 .93
3524 5 .95
3832 7 .95
4164 8 .95
4516 9 .95
4780 9 .95
5084 8 .95
5368 7 .95 knock here?
5868 11 .95
6104 12 .95
6324 12 .95
6528 13 .95
6724 11 .95
6880 22 .95
6064 34 .45 <pull done
#2
Rpm Timing 02
2816 27 .19
3016 23 .79
3152 21 .39
3288 19 .29
3436 6 .93
3680 5 .95
3960 6 .95
4240 7 .97
4544 7 .97
4852 9 .95
5120 7 .95
5392 8 .95
5652 10 .97
5880 12 .97
6092 12 .97
6312 13 .97
6528 10 .97<done, little too early I guess
I guess after typing all these I can see where I may need to add some fuel, but still why is it only reaching 13 degrees max?
