pte sc6152e..What size injectors DO I NEED
626freak
64
Dec 31, 2007
new castle, Indiana
im upgrading to a pte sc6152e from a 16g on my built 6bolt with a 255 pump and 680cc injectors....im going to be running 16psi low boost and 22psi high boost.....will i need bigger injectors or not
780, 880, or 1000cc injectors should do it for you.
You should be able to get away with 680's on low boost.
It all depends on your total goals for your car. What will you be tuning with, afc or link? If you are tuning with Dsmlink I would go as big as you want and be done with injectors.
im tuning with an SAFC,MAF-T,keydiver chip................how many pounds should i be able to run on 680cc's.
Should be able to see 22... but I dont think thats the best sized turbo for this application, a bit big for this low boost level.
What size a/r exhaust?
