PTE 50 Trim + I/C pipe
Flash
3,359
14
Nov 30, 2003
Highlands Ranch, Colorado
I want to get a PTE 50 trim, probably the SCM5027 (still undecided). I was wondering if I could use my old Dejon Tool lower 'S' pipe I have laying around from my T25 days, and connect the turbo to it with a 90 degree elbow coupler.
It sounds like it could work, but I'm just unsure.
Well, considering fabrications skills common to DSMers, I'm sure you could get it to work :tease: If you are running a side to side FMIC, your best bet is to get a 2 J-pipes with a large radius to connect to your existing FMIC. If you are still on the SMIC, a single Jpipe with a straight extension would work too.
Best of luck, and with imagination, you could make it work :thumb:
Well I would imagine with a 90 degree elbow coupler on the turbo it would be a lot like the T25. And in theory would connect right up.
BTW, I have a Greddy intercooler. So the lower pipes are in the same place as where the stock SMIC useto be.
I use to run the dejon tool lower ic piping with my greddy big fmic and pte 50. I don't know which dejon lower pipes you have but I have the one that includes the 90 degree elbow. then the S pipe, so it might be similar and you would just need to get the elbow.
Now I run a bigger better cheaper XS FMIC kit. My how its strange to say that. :)
