Ps stop leak ??
Cheap way is to replace the worn o-ring at the PS-Pump line fitting. If it is in the rack, good luck with that. Best to replace the rack if they start leaking. Stop Leaks are just temporary, and clog some of the small paths that are needed to flow.
Where is the leak exactaly? i have a leak on the banjo bolt that goes to the pump itself leaks out the top of it. even after using copper crush washer LOL so im kinda in the same boat depending on where yours is. Im gonna use some blue loctite on the threads with the copper crush washer and see if that stops it. :)
You can pick up a rebuilt unit for $200-250 or a rebuild kit for $50-100. Depending on what you wanna do.
Me personally would love the experience of rebuilding my own rack. BUT I won't look forward to it. I found recently that my PS resevour is low and I've noticed a puddle under car that isn't motor oil or tranny fluid. But PS fluid. Appears to be leaking from my rack. I'll find out better when I go to replace my tie rods.
  • Wanted 6 bolt NT water pipe
    • chrisman287
