projector headlights
They will bolt right up, and to use your factory headlights, be sure to get the kind that projector calls for.
You would get the right head lights first for the 2ga or 2gb, then when buying the housings, look for the bulb type.
The vendor will normally post the bulb size along with the ad. Ask before placing the order/purchasing them.
Other modifications: Depending on the specific housing you buy, if they come with halo rings and leds, you will need to splice those into a power source.
Also you stated that you do not want hids "now" so does that mean you'll be buying a set later? If so then your "halogen projectors" will not net you the best visibility because of the design differences. When you buy your hid set you might want to consider a retrofit with oem hid projectors for the greatest visibility.
When you get to that point here is an excellent comparison with pictures to show you what i'm talking about:
Why I can never go back to HID kits in halogen projectors... Pic Intensive - Club Lexus Forums
Good luck:thumb:
