infernal
- 0
- Aug 24, 2005
Calgary,
So I just bought a car from this guy in Batavia, IL and found a few problems. One, he said it wasn't in an accident and it clearly was. Looks like a fender bender, but they tried to do some sort of hack job with the repair.
Long short, the fenders need replacing and the front bumper is salvageable at best. Undercarrage looks fine from what I can see. Theres a bit of rust on in the engine bay where the struts are.
I tried to pop the trunk open, only to find it doesn't pop open all the way. After pulling the lever it clicks up and trys to open, but its being stuck on something. Only comes up about an inch at best, then I have to push it down to close. Any ideas?
I'm an ex honda guy. Raced an RSX Type S for a while, and I'm a bit concerned with a noise coming from the engine bay. If this car was an RSX I'd defiantly take it in to check the valve lash, but... Basically what it sounds like is a very faint ticking. I haven't heard another GSX, so I'm curious if I should get this car into a dealership immediately or if this is normal.
Thanks guys!
Thanks guys!
As for the hatch, watch to see if its binding on anything, if not its probably the hatch struts. Relatively cheap fix. Just swapped my hood struts off of my other car for $20 a piece from Crappy Tire(seeing you're in Calgary I'm sure you know what I'm talking about).
