nice97civic
- 448
- 56
- Jan 29, 2004
lancaster,
Pennsylvania
so here's the story. I had a bad ISC motor that I just replaced on my '95 GST. I removed the tbody elbow, and battery to perform the surgery. Removed bad motor, bolted down the new one, replaced battery and tbody elbow so now im ready to fire it up to see how she runs. Upon starting, the idle is back to normal right around ~750 with minor adjustment. However a problem arose with the throttle. When I blipped the throttle, there was a slight hesitation before the rpm's went up. Also, the fan's are on at idle, and for some reason there was smoke coming from underneath the dash on the passenger side. There are no unhooked wires, everything is back in the exact place it was before I replaced the motor. Anyone have any clue what the problem might be? Should I just let it idle for a while to see if it works itself out? I'm super confused as to what the problem is. Someone please help.
-Matt
EDIT: after restarting it I let it sit for a while and everything worked itself out. she's ready to play.
-Matt
