Problem With My Talons Engine
domothegreat18
87
Aug 24, 2009
Napanoch, New York
Hello I Have 93 Talon 4g63t 7 Bolt... I was driving and it started over heating, next thing i new it started to smoke and oil started dripping in large amounts. The car started to stall and idle weird as well. I understand that most of the smoke was from the coolant... The next morning i refilled the oil and started the car... It turned over but there was a constant clanking noise at the bottom half.. I've looked up the possible problems such as crank walking but i don't think that is the problem. (and crank walking for 6bolt not 7bolt) So can anyone give me any advice or help me with the situation!!???
7 bolts were the ones for crankwalking. However that doesn't sound like your problem. Drain the oil. See if there is bearing material in it. Sounds like you may have some bad ones.
I was thinking it might be a bearing as well... I'll try draining the oil tomorrow and then let you guys know if i find anything new. I also forgot to mention that the head cover was loose because of the previous owner using small screws. Do any of you think because it was loosely covered that the pressure caused a spill of oil which eventually led to over heating?
Your gonna end up rebuilding the entire bottom end, i would almost guarantee that there is a rod bearing thats completely shot.........try importperformanceparts.net ive had alotta luck with the topline rebuild kits they sell, or if youve got the cash to spend hit up slowboy and buy all new internals.... :banghead:
  • For sale 4G63 ARP 7 Bolt Head Studs
    ARP 7 Bolt Head Studs $65 + shipping & paypal fees* torqued onceYou must be registered to...
  • For sale 1g 1G OEM Knock Sensor ( great condition )
    1G OEM Knock Sensor $85 + shipping & paypal fees* sensor is in great conditionYou must be...
  • For sale 4G63 NEW ARP 4G63 Main Studs
    NEW ARP 4G63 Main Studs $50 + shipping & paypal fees* these are $81 onlineYou must be...
  • For sale 4G63 NEW Ferrea Competition Plus Intake Valves
    NEW Ferrea Competition Plus Intake Valves $140 + shipping & paypal fees* these are 8 Intake...
  • For sale 2g S90 Throttle Body
    - S90 Throttle Body, brand new. Purchased this month from STM. Comes with the FIAV block off...
    • Bedicine
