1G Problem with delrin shift cable bushing
Nuzzi
158
5
Jan 11, 2014
Torrington, Connecticut
I installed a set of new delrin shift cable bushings today made by Torque Solutions and have a concern. The selector cable bushing fit great, but the shift cable bushing has a lot play where it should press into the cable. The stock rubber bushings were installed previously, is it possible the eyelet is stretched or did I get a slightly small bushing? It is loose enough that without the clip it falls right out, where as the other one had to be pressed in with plyers. I installed the selector bushing first so I didn't want to have to pry it out again to compare and risk damaging it.
