Jeff822
- 636
- 2
- Jan 22, 2006
Easton,
Pennsylvania
Ok, i had my greddy boost controller installed last week and all the settings are as low as they can go right now, but heres the problem, my cars is boosting to 23+ psi and hitting a fuel cut! So is this the boost creep or something with the boost controller? Right now i have a 3 inch DP 3 inch exhaust and I know this is probably causing the boost creep if thats what it is, could i solve this by getting the evo III O2 sensor housing? or any 3 inch O2 sensor housing? Right now i am still on the stock T-25 so what O2 housings will fit my stock manifold that can stop the boost creep? oh how do you change the boost controller from KPAs to PSI? still cant figure it out, thanks
I don't see how you could be creeping now if the only thing you did was add a MBC and set it to the lowest boost setting.
