power steering leek from passenger side
96_turbo_spyder
35
Feb 4, 2008
hialeah, Florida
hey guys I put in some ground controlle coils on this weekend and the car is super low, and today I was replacing one of my fog light bulbs and I see a leek... it is leaking from the passenger side steering arm, the rubber boot is broken. Then I look on the driver side and the boot is also broken but its not leaking... how can I fix this?:confused:
So the rack and pinion is leaking from the passenger side seal? Replace the rack and pinion.
P.S. I did a quick check and didn't come across a removal and installation. I would try vfaq or if you have a haynes manual. I know its not the easiet to do at home but it can be done. Sorry I don't have more time to help you at the moment. I'll check back.
