power steering leak again
Do I have to remove part 14 to change the orings. It seems they are no oring between the line and 14 and between the line and the nut? Also no washers anywhere?
Thanks again I appreciate a lot
No, you just take off the nut, take off the banjo fitting , change the two o-rings, smear some fluid on them, put back on the fitting (but don't force it), and then put on and tighten the nut.
No. You keep 14 on the pump. There are two o-rings on it.
