posting racing logs.. need some help
time4anotherdsm
May 3, 2005
new york, New York
on my second run while i beat an sti i decided to log my car. here is what it looks like
Time,RPM,Knock,Timing,O2,Air Temp,Fuel Trim High,Fuel Trim Mid,Fuel Trim Low
00:00.20, 4688.0,0.0,39.0,0.82,77.0,90.0,131.0,140.0
00:00.40, 4781.0,0.0,37.0,0.84,77.0,90.0,131.0,140.0
00:00.58, 4844.0,0.0,28.0,0.82,77.0,90.0,131.0,140.0
00:00.94, 5063.0,0.0,26.0,0.88,77.0,90.0,131.0,140.0
00:01.11, 5469.0,0.0,25.0,0.88,77.0,90.0,131.0,140.0
00:01.26, 5625.0,0.0,27.0,0.88,77.0,90.0,131.0,140.0
00:01.43, 5844.0,6.0,27.0,0.88,77.0,90.0,131.0,140.0
00:01.56, 6000.0,12.0,24.0,0.88,77.0,90.0,131.0,140.0
00:01.71, 6219.0,12.0,24.0,0.88,77.0,90.0,131.0,140.0
00:01.83, 6375.0,12.0,24.0,0.88,77.0,90.0,131.0,140.0
00:01.98, 6500.0,12.0,23.0,0.88,77.0,90.0,131.0,140.0
00:02.11, 6813.0,11.0,23.0,0.88,77.0,90.0,131.0,140.0
00:02.25, 6938.0,11.0,22.0,0.88,77.0,90.0,131.0,140.0
00:02.42, 6906.0,11.0,26.0,0.67,77.0,90.0,131.0,140.0
00:02.61, 6469.0,7.0,42.0,0.12,78.0,90.0,131.0,140.0
00:02.81, 5875.0,0.0,45.0,0.49,77.0,90.0,131.0,140.0
00:03.02, 4750.0,0.0,29.0,0.71,77.0,90.0,131.0,140.0
00:03.25, 4656.0,0.0,25.0,0.86,77.0,90.0,131.0,140.0
00:03.47, 4875.0,0.0,22.0,0.9,77.0,90.0,131.0,140.0
00:03.65, 4969.0,0.0,21.0,0.9,77.0,90.0,131.0,140.0
00:03.81, 5000.0,0.0,21.0,0.9,77.0,90.0,131.0,140.0
00:04.01, 5156.0,2.0,22.0,0.9,77.0,90.0,131.0,140.0
00:04.19, 5281.0,1.0,22.0,0.88,77.0,90.0,131.0,140.0
00:04.38, 5313.0,1.0,23.0,0.88,77.0,90.0,131.0,140.0
00:04.55, 5469.0,1.0,24.0,0.88,77.0,90.0,131.0,140.0
00:04.69, 5563.0,4.0,23.0,0.88,77.0,90.0,131.0,140.0
00:04.86, 5656.0,8.0,23.0,0.88,77.0,90.0,131.0,140.0
00:05.01, 5719.0,13.0,23.0,0.88,77.0,90.0,131.0,140.0
00:05.13, 5813.0,13.0,23.0,0.88,77.0,90.0,131.0,140.0
00:05.34, 5906.0,12.0,25.0,0.88,77.0,90.0,131.0,140.0
00:05.48, 6063.0,13.0,25.0,0.88,77.0,90.0,131.0,140.0
00:05.61, 6000.0,13.0,23.0,0.88,77.0,90.0,131.0,140.0
00:05.73, 6156.0,13.0,25.0,0.88,77.0,90.0,131.0,140.0
00:05.88, 6188.0,12.0,24.0,0.88,77.0,90.0,131.0,140.0
00:06.03, 6344.0,12.0,24.0,0.88,77.0,90.0,131.0,140.0
00:06.17, 6344.0,16.0,23.0,0.88,77.0,90.0,131.0,140.0
00:06.28, 6500.0,16.0,22.0,0.88,77.0,90.0,131.0,140.0
00:06.44, 6531.0,17.0,22.0,0.88,77.0,90.0,131.0,140.0
00:06.57, 6500.0,16.0,23.0,0.88,77.0,90.0,131.0,140.0
00:06.69, 6656.0,16.0,23.0,0.88,77.0,90.0,131.0,140.0
00:06.82, 6750.0,16.0,20.0,0.88,77.0,90.0,131.0,140.0
00:06.98, 6750.0,16.0,22.0,0.88,77.0,90.0,131.0,140.0
00:07.11, 6719.0,15.0,22.0,0.88,77.0,90.0,131.0,140.0
00:07.23, 6781.0,15.0,21.0,0.88,77.0,90.0,131.0,140.0
00:07.38, 6938.0,15.0,21.0,0.88,77.0,90.0,131.0,140.0
00:07.57, 6531.0,15.0,29.0,0.8,78.0,90.0,131.0,140.0
00:07.77, 5969.0,0.0,44.0,0.04,77.0,90.0,131.0,140.0
00:07.98, 4969.0,0.0,30.0,0.04,77.0,90.0,131.0,140.0
00:08.18, 5094.0,1.0,25.0,0.86,77.0,90.0,131.0,140.0
00:08.38, 5250.0,1.0,24.0,0.88,77.0,90.0,131.0,140.0
00:08.56, 5219.0,0.0,24.0,0.88,77.0,90.0,131.0,140.0
00:08.76, 5281.0,4.0,22.0,0.88,77.0,90.0,131.0,140.0
00:08.93, 5375.0,4.0,22.0,0.88,77.0,90.0,131.0,140.0
00:09.06, 5438.0,10.0,21.0,0.88,77.0,90.0,131.0,140.0
00:09.25, 5438.0,10.0,21.0,0.88,77.0,90.0,131.0,140.0
00:09.40, 5438.0,10.0,21.0,0.88,77.0,90.0,131.0,140.0
00:09.57, 5500.0,10.0,21.0,0.88,77.0,90.0,131.0,140.0
00:09.76, 5563.0,10.0,22.0,0.88,77.0,90.0,131.0,140.0
00:09.93, 5594.0,10.0,22.0,0.88,77.0,90.0,131.0,140.0
00:10.07, 5625.0,14.0,22.0,0.88,77.0,90.0,131.0,140.0
00:10.22, 5656.0,14.0,23.0,0.88,77.0,90.0,131.0,140.0
00:10.35, 5719.0,13.0,23.0,0.88,77.0,90.0,131.0,140.0
00:10.51, 5719.0,13.0,23.0,0.88,77.0,90.0,131.0,140.0
00:10.64, 5781.0,13.0,23.0,0.88,77.0,90.0,131.0,140.0
00:10.80, 5875.0,13.0,24.0,0.9,77.0,90.0,131.0,140.0
00:11.01, 5875.0,12.0,24.0,0.92,77.0,90.0,131.0,140.0
00:11.22, 5875.0,10.0,40.0,0.75,77.0,90.0,131.0,140.0
00:11.43, 5750.0,0.0,45.0,0.69,78.0,90.0,131.0,140.0
00:11.61, 5750.0,0.0,45.0,0.67,78.0,90.0,131.0,140.0
00:11.81, 5781.0,0.0,45.0,0.65,78.0,90.0,131.0,140.0
00:12.02, 5688.0,0.0,45.0,0.76,78.0,90.0,131.0,140.0
00:12.22, 5688.0,0.0,45.0,0.67,78.0,90.0,131.0,140.0
00:12.43, 5656.0,0.0,45.0,0.06,78.0,90.0,131.0,140.0
00:12.61, 5625.0,0.0,45.0,0.04,78.0,90.0,131.0,140.0
00:12.81, 5594.0,0.0,45.0,0.04,78.0,90.0,131.0,140.0
00:13.02, 5563.0,0.0,45.0,0.02,78.0,90.0,131.0,140.0
00:13.21, 5438.0,0.0,45.0,0.02,78.0,90.0,131.0,140.0
00:13.39, 4906.0,0.0,45.0,0.02,78.0,90.0,131.0,140.0
00:13.56, 4594.0,0.0,31.0,0.02,78.0,90.0,131.0,140.0
00:13.72, 4156.0,0.0,29.0,0.02,78.0,90.0,131.0,140.0
00:13.89, 3813.0,0.0,28.0,0.02,78.0,90.0,131.0,140.0
00:14.06, 3469.0,0.0,27.0,0.02,78.0,90.0,131.0,140.0
00:14.22, 3156.0,0.0,26.0,0.02,78.0,90.0,131.0,140.0
00:14.38, 2844.0,0.0,26.0,0.02,78.0,90.0,131.0,140.0
00:14.52, 2594.0,0.0,25.0,0.02,78.0,90.0,131.0,140.0
00:14.68, 2313.0,0.0,25.0,0.02,78.0,90.0,131.0,140.0
00:14.84, 2031.0,0.0,24.0,0.02,78.0,90.0,131.0,140.0
00:14.98, 1781.0,0.0,17.0,0.02,78.0,90.0,131.0,140.0
00:15.14, 1531.0,0.0,11.0,0.02,78.0,90.0,131.0,140.0
00:15.27, 1313.0,0.0,8.0,0.02,78.0,90.0,131.0,140.0
00:15.43, 1031.0,0.0,16.0,0.02,78.0,90.0,131.0,140.0
00:15.56, 813.0,0.0,17.0,0.02,78.0,90.0,131.0,140.0
00:15.71, 688.0,0.0,16.0,0.02,78.0,90.0,131.0,140.0
00:15.85, 625.0,0.0,16.0,0.02,78.0,90.0,131.0,140.0
00:16.00, 719.0,0.0,16.0,0.02,78.0,90.0,131.0,140.0
00:16.14, 750.0,0.0,16.0,0.02,78.0,90.0,131.0,140.0
sry its a bi*** to read first time using pc log reader. and my air temp thing is broken too as you can see. any suggestions how to get rid of that knock. this was from top of second gear to fourth gear.
In 3rd gear only (don't shift), go WOT from 2800 RPM to redline, and only log RPM's, timing advance, O2's and throttle. It will make it easier to see what's going on.
what a cluster-
Whats the point of logging O2 when going full throttle? O2 trims go to 100 and O2 goes to 0.0. so logging it at full throttle is useless. Now unless for some reason mine only does that because I have a VPC (i dont know if that would be why or not). Can someone explain this to me? Thanks.
