izzone913
- 62
- 2
- Feb 15, 2008
Midland,
Michigan
got mine. TPS
.My Adventure To Solving My Backfire Problem...
Here is what is HAPPENING:
- First and Second gear works just fine at full throttle..
- Third, Fourth, and Fifth Gear backfire at approx. 4,000-5,000RPM... anywhere before or after that will pull just fine.
ALSO: i notice that my exhaust leaves black residue onto my back bumper... AND my oil somewhat smells like gas is going into it and i am guessing its from gas not firing properly.
SOLUTIONS I HAVE TRIED:
- Replaced Sparkplugs (NGK)
- Boost Leak Test. (Three leaks found and fixed)
- Replaced One Coil Pack (THAT had solved the backfire issue only for a moment and so maybe all i need to do is replace the other coil pack to completely fix the problem)
PARTS I AM BUYING:
- Oil Filter
- Another Coil Pack.
OTHER INFORMATION:
- (if you need more information let me know i will fill it into this section.)
- i wanted to get this problem fixed so i can run my car on the dyno, and race my brothers Mitsubishi Galant which we had swapped his automatic transmission to a manual and swapped the engine for an Eclipse GTS engine. (He thinks he can beat me, but i want to show him what a true Mitsubishi Eclipse GS-T can do.
Have you tried plug wires and using the proper heat range plugs gapped at .27-.28?
