Possible Vaccum leak?
eder-loco
133
Feb 19, 2006
pasadena, Texas
So this about 2 weeks ago. i parked my car. Due to Ike Hitting Houston, it ran fine, idle fine. everything Good as golden.
This afternoon i push it outside, battery was dead. well it starts to idle at 1800rpm.
i mess with the biss screw and Nothing. And the idle does not move.
So i look around and nothing. everything seems just fine. TB is new, Sensors were just fine before.
but i did notice that my brake reservoir was leaking a bit, Because i had moved it to fit my FPR. So i did my research and found that there can also be a Vac leak in the break System?
If so Where? While the car idles at 1800RPM, i would start stepping on the brakes back and forth and the rpms start to go up and down. from 1400rpm to 1800rpm.
Any ideas?
