Possible to log UEGO with pocket logger?
oplix
217
Mar 9, 2008
Zion, Illinois
I have the pocket logger kit from pocketloggers.com for my 2g and a AEM UEGO wideband. I know the UEGO supports datalogging but I'm wondering if and how you can sync it to a pocketlogger.
thank you.
Not quite sure if you can with pocketlogger. I just know with MMCD you just have to use the EGRT output to log the wideband, then convert that reading into AFR.
I know how to go about it on a 1g but not sure on your 2g. But at any rate be prepared for AEM's output on the gauge to read different than their 0-5v analog output that you would be logging.
thank you.
Cut the Rear o2 sensor input voltage to the ecu and wire in the 0-5v signal wire from the wide band. Then log rear o2. Then just use the conversion chart you got in the manual with the wideband. Or download the conversion chart off of AEM's website. Oh and if you are wondering if it will through a code for the rear o2 signal out of range, it wont. Have fun. There you go.
