Possible Failing Throttle Position Sensor
marcman804
484
11
Mar 5, 2005
Cumberland, Virginia
I drove my car yesterday and it was falling hard in the upper rpm's so I figured it may be a boost leak. I removed the turbosmart bov and went back to the 1g bov and also did a boost leak test and there were no leaks. I took it out again and got the same results, it would fall hard in the upper rpm's and jerked to redline. The only other thing I figure it could be is the tps because I have an evo intake manifold with a 1g throttle body. I read up on how to check it but I was wondering if I could use evoscan to set it. I am currently using an eprom ecu but I have the complete evoscan/ecuflash set up, its just not installed on the car. At the time I would like to keep using the eprom ecu with the keydiver chip. Has anyone been able to log and set the tps with evoscan on a eprom ecu?
