possibile CW? clutch prob please help
vtlaxplaya16
60
Oct 13, 2003
my clutch (stock pressure plate, 2100 disc) is acting weird, im pretty sure i need a new clutch but ive been noticing that under load (boost) my clutch gets a little stiffer to push in. Its not alot heavier to push in but its definatley noticeable. I know that a sign of CW is the clutch changing stiffness alot. I also noticed that the clutch pedal "clicks" half way down. Any info would be much appreciated.
I find it hard to believe that you could possibly have CW from that clutch set up. Does your clutch pedal drop to the floor when you make left turns? Do you hear a tick from the engine bay while it's running, and it's not your lifters.
It may only be because your clutch pedal is out of alignment
Try this, and let us know what happens: http://www.roadraceengineering.com/clutchandflywheeltech.htm
