RipperXX
- 5,786
- 172
- Feb 23, 2003
Royston,
Georgia
Ok, so I removed the stock flapper from my E3 exhaust houseing, which was a PITA. (first tried the blow torch, and soon realised this isn't plain cast iorn and it doesn't like the torch) So I went to the grinder after breaking the saw blade on my hand held band saw
Thats stong shit there.
Anyway got it out, and I need advice on the best way to port the passage, im planning on just removeing that "ring" that extends outward, opening it all up, which will take a few hr's to do. But im not sure this is the best idea, as it seems to me that helps direct the exhaust out that passage....
If anyone could post pics of there work where they ported the waste gate passage that would be grate. or just post a pic showing what I need to remove, for best results.
THANKS! again im needing this info ASAP as im currently at a stand still waiting for the info before I go on and potentialy screw it up.
Thats stong shit there.Anyway got it out, and I need advice on the best way to port the passage, im planning on just removeing that "ring" that extends outward, opening it all up, which will take a few hr's to do. But im not sure this is the best idea, as it seems to me that helps direct the exhaust out that passage....
... I will have to try a stirght line to see what the minimum is. But the waste gate hsa a 1bar spring in it, which if memory serves is 14.7psi.
