DiamondStar90
- 209
- 5
- Oct 9, 2010
Waco,
Texas
can you port the 2g intake ports on head to match the 1g manifold?
Honestly, get a 1g head if you want larger ports. However the smaller 2g ports are excellent for velocity and it has a better design for air flow.
its just i dont have anyone locally selling a 1g turbo head with the water pipe needed to do the swap for cheap
The EvoIII/RVR manifold with a 1g tb is a huge upgrade.
How can this possibly be?
Worst/best kept secret in 4G63 world...
I don't quite understand what you meant by that.
I have a couple of 1g heads, I'd gladly trade for unbutchered 2g heads. Opening up the 2g head like that only to (maybe) match the flow of heads that can be had for about the cost of their weight in beer cans, is a waste.
But as mentioned above and in many previous threads... Yes, this can be done.
It's been proven to be an upgrade, it's provides lower end power using the shorter runners with higher velocity flow into the head. It's an upgrade over the stock manifold.
