InfiniteGSX
- 3,182
- 16
- Dec 10, 2002
Tijeras,
New Mexico
Seems like everyone is using this so I might as well. but from what it shows on the HAHN website, it adds 4 "extra" injectors... Is this correct? Or does it come with plugs for the stock injectors and changes the way its sprayed?
Do I HAVE to use Intake Manifold Injectors as well as the port Fueler Injectors, totaling up to 8?
If not, is the PF mounting system a must? Or could I just replace my stock injectors with the injectors they give and go from there and just run it straight port fueler system?
also, could someone supply some detailed photos of the install. Cause the photo they show is just soo tiny...
Thanks in advance.
Thanks in advance.
