polished valve cover good or bad ???
Mitsu725
211
Mar 22, 2004
DAVIE, Florida
If you polish your valve cover does it get hotter, like does it not let off heat as easy, kinda like crome holds heat ??? I dunno thought about doing it but had a brain fart first, also what looks better polished or painted open for ANY ideas...
:talon: polishing is not the same thing as chroming...it doesn't matter except the fact that it looks good...if you can get your hands on a polished valve cover, put it on. wish I could :cry:
You decide what looks best. The valve cover doesn't play enough of a part in engine cooling to affect the temperatures, regardless what you do with it. But polishing won't cut down on its heat-shedding abilities, it's still aluminum.
In theory polishing aluminum does diminish the ability of a part to cool. If you take a normal, "rough" part and polish it, you've decreased the surface area. The greater the surface area, the greater the cooling ability.
Granted, it's a miniscule amount, and I doubt that you'll notice a temp difference, but the theory is there.
