Pocketlogger OBDII sample rate
Devicex said:
I get about 5... :thumbdown
WOW!!!!! Have you went into the pocketlogger options part where they let you change your sample rate? It starts out really low unless you change it. I really don't think your car should ever log that low. I get my 95 TSI on 11 per sec w/ no data drops. And the laster 2gs get higher rates then that. I have to believe you have to just find the options screen in the pocketlogger program cause that is ridiculusly low.
Damn... I'm with DeviceX, I can only get 4-5s/sec. I'm using v2.0 on a Palm m515 and have went through and optimized it for my ECU... is there another way to get more? It seems like even after optimizing it I still get 'errors'. Is this normal or could there be a problem?
I found that using the automated byte timing option in V2.0 left me with a low data transfer rate. I messed around with it manually and was able to get things up to about 10 samples/sec.
I have the obd2 from digital tuning and i can't get a sample rate higher than 6-7 samples per second. that is with the auto byte timing. how would I up that number?
-Dan
Im sorry to say it but I was getting around 15 samples per second. Unfortunately I can't give you guys any info. I havent used pocketlogger in awhile because I broke a timing belt. Was fixing my car and mother nature dropped about a foot of snow in just two weeks. Theres no way I can get my car out of the backyard, that and the head still needs to go on.
I will say tho, use the auto feature to get it close to where you need it and then manually change things. I was seeing around 10 with the automated feature and I tweaked mine up to around 13-15.
    • Sdcryan1
