PN for tranny mounting bolts
absolute_DSM
1,650
14
Jan 29, 2006
Boise, Idaho
Ill be calling Mitsubishi tomorrow for hopefully an answer - but in the meantime, does anyone know the PN for the tranny mounting bolts to block for a 2g?
Ive searched around CAPS, the backup CD, and the Chilton and Haynes with no luck.
This is about all I have figured out. (pic)
If anyone can help out, let me know. Also, Im looking for the PN because I prefer OEM in this department. Thanks
The bolts that go through the transmission and screw into the block:
MF140471 - 10x65mm (1)
MD740892 - 10x43.5mm (1)
MF140266 - 10x40mm (2)
If you need the part number for the bolt that goes through the block and screws into the transmission, it is:
MD706012 - 8x60mm (1)
Outstanding :thumb:
Did you happen to find those in CAPS? If so, where at?
Thanks a lot, that saves some headache.
Outstanding :thumb:
Yes, I found them in CAPS. Section 22-110 (M/T Case), page 2. Once you get to section 22-110, click on the right arrow in the tool bar at the top. That will take you to the other pages for that section.
You get the gold star for the week. Thanks for the heads up.
Ordered all the bolts I needed last night. Time to drop the 2.3 in. :thumb:
