Pls Help me!!
GORBS88
549
3
May 26, 2004
Oliver, BC, Canada
Ok i have a 92 tsi awd... My mods wont make a difference for my question...i finally got around to doin a test for boost leaks...i found a small one behind egr and fixed that....before that i could only seem to get 2-3 psi on my gauge, i was pumpin till blue in the face :barf: ....i fixed that one and now i can get 5psi on gauge but hear a big leak down by the turbo!!! :thumbdown .... what the heck can leak there???is there a gasket between the intake and exhaust side of turbo??? pls help me...not to sure why the turbo can be leakin....and i mean it is bad.....you can hear it really loud....the most i can pump up is to 5psi and i am given her sh$t with the shwinn bike pump...pls... :cry:
-Use a air compressor!!! a bicycle won't only work on small leak, if you use an air compressor, you'll know where on the turbo is the air leaking from.
thanx guys, will look into it better, will try a compressor....ummm is it worth takin the 14b apart and fixin it, or should i just upgrade now.....the turbo has 108k miles on it....is it worth fixin????????????????? pls... if not then i will go and buy a small 16g....pls let me know if it is worth puttin time into a miled out turbo......tnx
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
