please help. random severe misfire?
95gsxxx
35
Oct 1, 2013
philadelphia, Pennsylvania
i took a video my my gsx doing the intermittent misfire . any help is appreaciated
now this will happen when ever it feels like doing it. during idle or during cruising, the rpms will just fall and feels like its running on 2cylinders. the only dtc i got was cylinder #1 misfire. if i wait 10mins and restart the car it will run normal again.
what ive done
blt
changed coils,wires,plugs
checked my ecu for leakage
changed my cas
timing is dead on
alternator is brand new
injectors are getting 12v and signal from ecu
the only thing that has me confused is that sometimes on cylinder #1 i will get either 150psi compression or 0 compression. bottom end issue?
