please help me.
supermario300hp
279
Dec 11, 2011
Countryside, Illinois
ok so i have problem just swapped in my 850cc injectors, 20g turbo and dsmlink, i also have a vrsf fmic,2.3 built bottom end. basically i need help tuning my car with link. if anyone has base settings i should use please help i have no idea what to do next and im gonna need my car for work. thanks
Start here: start [ECMTuning - wiki]
There are lots of tutorials/walk throughs to get you started. You will be able to get your car drivable with the link I provided. You don't need to WOT tune your car just to drive it to work just don't do any WOT pulls and you'll be fine till you can have someone tune your car or learn how to do it yourself.
You might look up and befriend a local tuner/ grease his wheels alittle bit to help you. I'd think about finding a different source of transportation until you you get the car running smoothly.
Just follow the link posted above, it will guide you to how to set your global fuel and deadtimes. Just dont go full throttle. Tuning for idle and cruise its extremley important. Make sure you follow the guide and dont skip no steps. It takes along time but is well worth it in the end.
yea thats basically all i did so far. anybody in my area with experienece in tuning? Theres a case of beer of your choice in it for you. LOL I tried going WOT and it was stuttering really bad and stuff so i wont do that again.
no speed density. but ill chaeck it out. thanks. it seems to run really good now except when i go full throttle. once it hits about 5k rpm it stutters but still is pulling very hard. any tips?
