Please help diagnose my car!
PieEyedPiper
DSM Wiseman
5,580
65
Nov 13, 2004
North Bay Area, California
Alright, It was cold out this morning, so i woke up, got dressed, went outside and started up the car while I ate my breakfast. I let her warm up for maybe 8min or so. I went outside with my stuff and stopped dead in my tracks when i can hear the engine not running smoothly at all. Furthermore, WHITE puffs of smoke are eminating from my exhaust.
I get in, swearing my head off, and give her a little gas, only to find the small puffs would turn into a massive white cloud. It quickly vanished as I put it in gear and slowly rolled up my street, turned around and reparked my car. The check enigine light is now on.
What could be happening? did my head gasket spontaneously blow under the extreme pressures of my idle? Has my stock turbo blown? I need help!!!
Thank you! :cry:
when you find out whats wrong with your car let me know. i have a simliar case going on right now. i think its safe to drive. i drove my car to school for a week.
Well I took the advice and my fears were unfounded.
Turns out my code only meant I had a cylander 4 misfire, and the smoke was just unburnt shit from the cylander.
The solution though? New Plugs and Wires.
I'm order the accel (mm yellow) wires and some ngk 6 plugs (not the colder 7's).
I'm just glad its nothing I cant handle.
Well I can only think of two places for the coolant to leak from, HG and turbo. If you 're sure you saw coolant in the tail pipe, definitely do a compression test.
