PLEASE HELP clutch acting up
96atgsx
40
Sep 14, 2004
Columbus, Ohio
I have a 97 5 speed gs and the clutch is very light, checked fluid and was out. so i put more fluid in and it didn't help. could the master cylinder cause this problem?
PLEASE HELP!!!
So what you are saying is you pulled the reservior cap off and it was empty?
Is there still fluid in it after you topped it off?
Did you bleed the clutch?
Also look under your dash above the clutch pedal, is there any signs of fluid leaking inside the car?
Look also at the slave cylinder for signs of leakage.
Yep everything this guy said. ^
Im willing to bed its just air pockets in his lines. Bleed that clutch!
  • Wanted 6 bolt NT water pipe
    • chrisman287
