Please answer rim/tire question asap
go and try and see if they will fit... and asking if they're going to fit is the same question...i think they should look like the same size 5 lug
Yes they will fit, they have the same bolt pattern and the offset is +45 while our stock rims are +46. Don't go with any bigger tire then a 225 though or you will rub your suspension.
