pistons move in forged block too much???
tturbolife1
144
Apr 29, 2008
westwood, New Jersey
i bought a forged 6bolt bottem from someone in my area, it has ross pistons, cower rods arp everything .20 over. and SHINNY(under 3k). the guy told me that the freeze plug kept popping out so he didnt feel like dealing with it because he couldnt find the problem and decided to sell it to ME. As i was cleaning the pistons because i spilled assembly lube in one of the cylinders, i noticed the pistons move from side to side, (so much that they make a click sound ) then i noticed that when i hand cranked the engine, while the pistons go up and down there is a line of assembly lube left over after the piston has passed over it already, always in the same spot, toward the top middle-ish about an inch in length. should i be worried at either of these?
The piston moves around because forged pistons require looser piston-to-wall clearances, up to x3 or x4 that of stock. As for the line of assembly lube, it may be that there is some lube pooled on top of the rings and as you move the piston up/down, the lube sticks to the cylinder wall where the ring gap is and doesn't get scraped.
thank you i will try that asap.
i brought it to a local machine shop and he said everything is fine (i forget the exact numbers)and he didnt even charge me for a new oil pan gasket LOL and he said the same thing you said , the lube is thin, and it was probably left over when it goes up and down
